TH400 Speedometer values
Old 09-06-2007, 08:38 PM
KsMySS's Avatar
Default TH400 Speedometer values
I didn't get any response in the PCM forum so I'll try it here. I just put a TH400 in my car and I'm unsure of the values to enter to get the speedo to work correctly. Right now it reads like 80 when I'm only going 30. The trans has:
GM8655291 GM Speedometer Sensor
GM8655315 GM Speedometer Drive Sensor Rotor
It looks like this:
The car used to a 6 speed and these are the values I have right now.
General VSS Pulses Per
Mile: 47758
Rev-Trans: 17.000
Final Drive Ratio
Ratio: 3.90
Trans/Revolutions/Mile: 817.8515
Tire Size: 28.00
Gear Ratio 3.90
Calculated Tire 96.17
I think I have to change the Rev-Trans from 17 to 40? Because the reluctor wheel in the T56 had 17 teeth and this new one has 40. But other than that I m not sure of the calculations I need to perform. Thanks for any help you guys can give me.
Old 09-06-2007, 09:13 PM
8a8mfh's Avatar
Thats what you have to do, change from 17 to 40.
Quick Reply: TH400 Speedometer values
