what is this gasket for?
hey guys. i ordered a tb plate that came with a gasket set. it came with a small circular ring shaped gasket. i am unsure of what it is for, and this throttle body was unassembled when i got it so i didnt remove any gaskets to know where the new ones would go.the only place that seems logical to me is the tps. but im thinking it also may just be a universal kind of gasket set, and the gasket may have been used in older tpi setups? thanks guys
I've never had to use one when I've had mine apart? It may be for the TPS, but I don't think you'll need it. The only gaskets that I can think of on the TB is the one that mates up with the intake manifold and the one on the bottom for the coolant passages.
