Speedometer FREAKING OUT!
Old 09-06-2007, 11:52 PM
Halloran's Avatar
Default Speedometer FREAKING OUT!
After my full out heads, cam, valvespring, oil pump, timing chain swap I started the car it actually drove it to Jiffy lube for a radiator flush. While driving I noticed the speedometer was TOTALLY FREAKING OUT! It was fluctuating from 10 to 50 mph and then back down then back up then steady then down. Is this normal after such a big engine upgrade? Will a computer tune fix the problem?
Thanks!
Old 09-07-2007, 09:18 AM
5.3LJimmy's Avatar
No that is not normal and a tune will not fix it. I can't think of anything that would cause that after a H/C swap. Make sure all of your grounds are connected and tightened properly. Other than that it may be a pinched or damaged wire, as the speed sensor wires do pass at the back of the heads.
Old 09-07-2007, 09:34 AM
markp03's Avatar
it's just stretching out for when you womp on it.
Old 09-07-2007, 11:00 AM
Halloran's Avatar
I'll check the grounds and the wires on the sensor at the tranny. I'm pretty sure that all the grounds are connected firmly to the back of the heads. Do you know by any chance which head the speedo wire grounds to? Driver or Passenger?
Thanks again
Old 09-07-2007, 11:12 AM
5.3LJimmy's Avatar
All the grounds are on the drivers side head. Three ground eyes on two different bolts. The passenger side head has the dipstick tube and a wire strap.
Quick Reply: Speedometer FREAKING OUT!
