bearing clearances....
Old 09-08-2007, 12:27 PM
thebufenator's Avatar
Default bearing clearances....
Alright, when measuring the clearnces for the mains, I measure the journal on the crank, then put the bearing back in and torque the cap down and measure inside with a bore gauge......
Question, do I need to use a new bearing, or can I use my old bearings that aren't worn?
That way I can order the correct bearings the first time......
*Using stock bottom end with new bearings*
also, I plan on clearances of:
#5 #4 #3 #2 #1
.0025 .002 .002 .002 .002
and then .002 on the rods.
The current valvetrain is:
stock heads/valves
CC503
GMPP 1.6RR
PAC1218's
LS7 lifters
stock pushrods
Are the clearances good? This is a dd, so.......
Old 09-09-2007, 10:50 AM
So nobody has done this?
One other thing, does it take a special tool to install piston rings?
All of mine need replacing.
Old 09-09-2007, 10:54 AM
ThoR294's Avatar
yeah... i forget the name, but you put the piston in it, and it like squeeze the rings... and then you put the tool above the cylinder, then slip the piston in
Quick Reply: bearing clearances....
