Diagnostics help on 02 firehawk
Car is a 2002 A4 firehawk w/ 29k on the clock. OK heres the deal, when i am going around 60 to 70mph and punch it into a down shift. It feels like it is missing the gear and going into neutral, the engine is revving but not going anywhere, then I let go of the gas and it goes back into gear. It hasn't done this when I punch it from a lower gear. (like when im in second and it down shifts into 1st)
Anyone have any idea what my problem is???
any help would be appreciated
At those speeds you are downshifting to 2nd. You need to have a transmission shop check it out. As a minimum I'd change the trans. oil and filter but it sounds like you might need more extensive work.
