power door locks not working, need help!
Back when I gutted the dash I blew a couple fuses inside the car. I replaced all the ones I saw were blown. Everything works correctly, except the button for the power door locks. The remote for the power door locks functions correctly as well. Anyone know how to fix this? I heard they use the fuse for the courtesy lights (which also function correctly). Thanks
On mine the power door lock button locks both using either door switch - are both of yours not working? Doesn't sound like a fuse in the lock circuit if it works with the remote. Any chance the switch got fried?
Don't know if this will help, but it's for a '95 - looks like it uses the power accessory fuse, or maybe the wire that taps into the IP harness is the problem? http://shbox.com/1/pwr_dr_lock_schematic.jpg
To be honest don't have a clue, only have diagrams for my year. Orange wires normally mean battery positive voltage - don't know what to tell ya other than to look around. Hopefully someone who knows for sure will chime in.
