ls truck pan/fit in an "A" body car
Look at the other A-body swaps around. I will be running an stock F-body pan w/ no mods. Just depends what mounts you use and if you don't mind drilling the crossmember. At the most the CTS-V pan should clear.
My concern w/ the truck pan is it hanging below the crossmember behind it. So if you hit a big bump you wack the pan instead of the crossmember.
