coolant
nobody knows? i read it on here but i cant find the thread anymore. i just flushed the **** out of mine and it only took 2 gallons? is that normal? or what? my low coolant light isnt on.. it was at first then it warmed up an went off?
mine took about 2 gallons of a 50/50 mix. but i didnt flush mine. i just changed the water pump so there was still some left in the block. start and stop your car a few more times. see if that will clear the low coolant light. i know thats a pretty common problem when you change the fluid
ok cool. when i was filling it back up i opending the bleeder closer to the battery an heard burst of air as i was filling. once i got a gallon ana half in the coolant started coming out of the bleeder. so i put the cap on an started it an i got a straight shot of coolant coming out. i used water bottle to catch it so it wouldnt cream my opti
anyone have a write up on how to do a manual fan switch?
