ses light, please help
The SES light came on, took it to a mechanic and 2 codes came up 410 and 412. He checked everything over and all sensors were fine, so he cleared the codes out. That night the SES light came on again so I took the car back to the same guy and the same 2 codes came up again. So he checked everything over and still couldn't find anything wrong. He said the last time he saw something like that the computer had to be replace. Does this make sense? I have reset it by pulling the fuses a couple of times but the light keeps coming on.
Re: ses light, please help
P0410 Secondary Air Injection (AIR) System
P0412 Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1
Replace a PCM for an A.I.R.-related problem? Sounds like it's time to get a new mechanic...
Since you threw the P0412 code, first check the AIR fuses and relays in the engine compartment. Next, check to make sure the solenoid relay wiring harness (above the driver-side valve cover near the fuel rail) to make sure it's connected.
