FAST 78 and stock TB issue
Old 09-17-2007, 09:43 AM
radkon's Avatar
Default FAST 78 and stock TB issue
Well I was out playing with the car yesterday and noticed this:
The PCV intake on the FAST 78 manifold interferes with the stock throttle body opening all the way
What the hell? Anyone else have this problem? The cable pulley is hitting the hose and preventing 100% opening. I didn't hook up anything to see if the ECM is "seeing" less than 100% but thats my next step. I'm thinking I'm gonna have to grind the pulley a bit to allow it to open all the way. Any other ideas?
Old 09-17-2007, 07:12 PM
JPH
JPH's Avatar
yeah, try thin walled hose or grind throttle cam arm a little. what i would do, is save your money and invest in a wilson 78mm t/b. you will not believe the diffrence it will make over a stock, or ported stock t/b.
Old 09-17-2007, 08:25 PM
LS1MCSS's Avatar
If you run across a 98 throttle body, cheap, you could get it. They have a smaller plate on the end of the throttle shaft.
Old 09-17-2007, 08:28 PM
Restricted User
socmguy's Avatar
yep, get the smaller throttle cam from an 01-02? car and that should solve your problems.
Old 09-18-2007, 08:12 AM
radkon's Avatar
Thanks guys I went to town on it last night with a file and my Dremel and got it just about all the way there. I just ground a tiny bit of material off the cable pulley and she's good to go. Will get pics later.
