another 10 bolt noise question
I USED SEARCH FIRST! but nothing sounded the same. my car is a 98 a4 with 3.23 and 85k on it, and ever since i got it at 82k it has made the same noise, whether i go straight or turn. anything over 1/2 throttle the rearend makes a knocking sound that gets quicker then goes away when i let off. i changed the fluid and it made no difference. i am hoping it something cheap, like an axle bearing or u joint. i dont want to spend alot on the 10 bolt. hopefully someone has had the same issue and fixed it. thanks for the help!
