Rear End Fluid Leak - What do you recommend?
Well I finally got the 4L80E into the car and on the road when I noticed my pinion happily leaking fluid onto the ground. I'm getting a 9" housing and axles in a few months so I just need her to hold on a bit longer. Zexel Posi and Richmond 3.73's with Royal Purple Syn in there now. Should I run a thicker 75/140 weight oil to slow the leak or just keep adding 75/90 as I go? It's not pouring out, but some is flinging onto the exhaust and tunnel.
-Dustin-
-Dustin-
