Do I have upgraded Hydraulics or not?? (2001 +)
Old 09-23-2007, 05:50 PM
soontobeLS1's Avatar
Default Do I have upgraded Hydraulics or not?? (2001 +)
Well, I have been having the sticking clutch pedal problem. I have done the drill mod and bleed.
I was just thinking about the year of the master cylinder etc. My car is a 2001. However, my ASC build date is Oct 11, 2000. Perhaps I didn't get the upgraded hydraulics????? If that is the case, then I need to buy an upgraded factory unit. Can anybody shed some light on this and say this is the problem.
Thx.
Hope somebody is in the know.
Old 09-23-2007, 06:27 PM
brad8266's Avatar
Its possible that the master is wore out. You could try a new one but it also could be the clutch as well. How many miles are on the clutch?
Old 09-23-2007, 06:28 PM
31,000 Miles on the clutch.
Old 09-23-2007, 06:35 PM
brad8266's Avatar
The clutch should be OK then, failing master is possible and is the easiest thing to replace.
Old 09-23-2007, 07:56 PM
bowtieman81's Avatar
Look on the bottom of the master cylinder cap, it will have 2 digits in the middle of the cap with a circle around them. That is the year of your master cylinder.
Old 09-23-2007, 11:34 PM
I will check under the cap....will let ya know soon!
Old 09-24-2007, 11:59 AM
So, I checked the cap on my clutch fluid resovoir...it says 00, so I assume that I dont have the upgraded master clylinder then.
Quick Reply: Do I have upgraded Hydraulics or not?? (2001 +)
