Keyless entry/Alarm and starting up
I just purchased a 1998 trans am. The battery in the Key FOB is dead and the remote doesnt work. When i open the door the alarm sometimes goes off but it shuts off as soon as I put the key in the ignition.
My problem is that sometimes the car wont start after the alarm goes off. The engine doesnt turn over. I havent had the car too long to notice a pattern, but it only happens when the alarm goes off. (Ive stalled a couple times and it will start up no problem).
Does anyone know if there is a fuel cuttoff switch that engages when the alarm goes off? Its only happened twice, but i dont know if I should be worried about a problem under the hood.
I don't know about your specific alarm, but there was an alarm with remote start installed on my Z28 when I purchased it. It would do odd things intermittently, shut the car off while driving, alarm would go off when opening the door. I ended up having to pay a shop to completely remove the aftermarket system. It was not cheap but it fixed my issues. I was surprised to find out that these aftermarket systems wear out faster than you would like them to, I will never put an aftermarket alarm on any other car I own. Just not worth the headaches down the road in my opinion. Sorry I could not help with specifics. Good luck.
