t56 clutch and pedal
Old 09-27-2007, 10:08 PM
spina74's Avatar
Default t56 clutch and pedal
I'm a 3rd gen owner, but i swapped out my 4spd auto to the lt1 t56 so i figured I could try to ask here, I've had the t56 in my car for over a month now and I love it, but when i push my clutch pedal all the way down there is this nasty squealing sound so i have to make sure i dont press the pedal down fully, and also my clutch doesn't engage until my pedal is almost fully up so basically by pushin the clutch down about 3 or 4 inches does the job and the rest of the room it has doesn't do anything, does anybody know what could be wrong.
Old 09-27-2007, 10:14 PM
thesource's Avatar
You are probably bottoming out the pressure plate and putting too much load on the throw out bearing .
Old 09-27-2007, 10:30 PM
wrencher
wrencher's Avatar
Agreed, I've seen that b-4 with many different applications.
An adjustable master cylinder might be the ticket for you.
Old 09-27-2007, 10:39 PM
spina74's Avatar
nevermind, i did some searching and the fact that im using the pedals from a 3rd gen is the problem because they have more movement than the 4th gen ones do, so there is no mechanical problems
Quick Reply: t56 clutch and pedal
