need asap help th400 or 4l80
i blew my trans in my 2000 T/A, i hvae about 520rwhp i can get a 4l80 for cheap or a turbo 400 for a good price that is built up, whats should i do, im putting a 4200 stall in it,
4l80e is it strong enough stock or should i go with th400?
please i drag race the car an drive it, need assistance trans is out my car already need a direction as what i should do my car cannot be down for every!!!
You can control a 4L80E with a tune change, I did mine with HPT and control it with the stock PCM.
I highly recommend the swap - just be aware if you're swapping from a 4L60E you will lose a little power with the swap but gain a lot more durability.
Rob (Bad30th)
Rob (Bad30th)
1 Post
Originally Posted by Strahley
Get a ratchet shifter from B&M or Hurst or something. You'll need one for a RMVB
You can use your stock shifter, the shifter dosent know what trans its on, its just a lever that pulls the cable. You can get a P-R-N-1-2-3 decal made for the console cover that would look factory. Thats what I was going to do when I had my th400... I just decided to go 4l80e instead (I wanted OD)
