C5 corvette output shaft measurement needed..please help
Old 09-30-2007, 08:51 AM
tomulrich's Avatar
Default C5 corvette output shaft measurement needed..please help
Can someone measure the following on a C5 automatic trans output shaft.
1. Total length of the output shaft from rear of trans to end of shaft (part sticking out)
2. distance the splines start and distance they end...from the transmission case rear
3. Complete length of spines (shoud be around 2")
Thanks for your help......
tom
Old 09-30-2007, 09:00 AM
FLT
FLT's Avatar
The shaft for the C5 is the same as any other 2WD shaft for the exception of a polished surface where the main case seal rides. I do not have a unit to make the measurements in front of me right now but why do you ask? Vince
Old 09-30-2007, 08:07 PM
tomulrich's Avatar
I am doing a conversion and wanted the lengths....it sticks out of the rear case approx 9".....I need measurments without a tailshaft housing....I dont think they are all the same???
Tom
Old 09-30-2007, 08:38 PM
FLT
FLT's Avatar
Give me a call at the shop tomorrow and we can discuss your conversion. I can give the measurements while we are on the phone and maybe add a tip or two. Vince 1-630-350-7776
