What # injectors good for me
Old 10-02-2007, 11:01 AM
BLWNLT1_T/A's Avatar
Default What # injectors good for me
I'm looking at some injectors,and was wondering what # I needed...
This is what I have (which is finally coming together!!!)
355 forged eagle bottom end/ 24cc dished pistons
Custom BRE cam
Lightly ported heads
Pacesetter LT headers/ 2.5" true duals over the axle
T56/3.73 gears
Walbro 255 LPH
ATI ProCharger P600B... From the research I have done., I'm looking at 8-12#'s boost.
(Plan on getting a N2O wet kit and spray a 50/100 shot)
I also have the in-line pump from procharger ,and there FMU so I want something big enough to do away with em.
Thanks in Advance for your help,
P.S. any 1/4 mile time estimates with my setup? I've got QA1's all round with stock springs in back.
Old 10-02-2007, 11:20 AM
Fire67's Avatar
All depends on the power your planning to make. Since the N20 is wet, it should have no effect on the injector size fwiw.
Old 10-02-2007, 11:27 AM
infinitebird's Avatar
Yeah the max power is really what you need to look at. 12 lbs of boost might require more injector than 8.
Old 10-02-2007, 02:27 PM
???? 8 Should be find but I was thing something like 50 # injectors.. tell me if i'm wrong
Old 10-02-2007, 04:07 PM
kinglt-1's Avatar
44# Should be about right!
Quick Reply: What # injectors good for me
