Solid Motor Mount Install Idea.
Old 10-02-2007, 09:54 PM
Grifter's Avatar
Default Solid Motor Mount Install Idea.
I was thinking about getting a set of solid motor mounts. I know that they're a pain to install but I was thinking; would it be any easier if I removed the k-member? Or is it still difficult to get at some of the bolts. I need to get the car back on the lift to get an idea, but I have just been running this through my head and figured I'd post it up.
This would not be done on the ground. It would be on a lift with an engine support bracket.
Thanks for any input.
Old 10-02-2007, 10:52 PM
arcticwhiteTA's Avatar
I think it would be a lot harder to drop the k-frame than to swap mounts. My friends and I JUST finished swapping in some spohn solid motor mounts tonight. It took us about 4 hours (on jack stands) to get the old ones out and the new ones bolted in. we used a swivel and some ratchet wrenches, some PB blaster and lots of WD-40. I haven't driven it around yet to feel the difference but it was a lot easier than I expected. The bolt holes really lined up well.
When you drop the k-frame, you also have to drop the front shock assemblies ( I believe). Lower and upper A-arms, struts, all that. It seems like it would be easier just to lift the motor a little bit.
Old 10-02-2007, 10:53 PM
3.4camaro's Avatar
It's so much easier with a lift. I have solid mounts, swapped when I did a k-frame swap. I have all Spohn stuff.
It's cake with a lift. The bolts are easy to get to.
Old 10-02-2007, 11:38 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I love my Spohn's. They probably took about 1.5 hours to install. I used a lift when I worked at a shop. That made it really easy.
Old 10-03-2007, 12:15 AM
Mudvayne's Avatar
If you can't get to a lift I'd just pay someone to do it if your headers are already in. I remember someone said the shop hours on replacing them were 3-5 hours I believe
Old 10-03-2007, 06:35 AM
Grifter's Avatar
The car will be on a lift, that's not a problem.
So how did you guys go about installing them on a lift that made it so much easier? Like I said, I need to get another look at them but dropping the k-member didn't seem to hard IF that would help the install at all.
Old 10-03-2007, 08:23 PM
Grifter's Avatar
I think you just have to unbolt the bottom of the shock(that bolts to the lower a-arm), outer tie-rods and lower balljoint.
I guess I wouldn't want to drop it all the way or else I would have to disconnect the PS lines. Maybe just drop it enough to get me more clearance.
Old 10-03-2007, 08:44 PM
theinstag8r's Avatar
Don't mean to highjack this thread BUT how does everyone feel about their solid mounts once there in.I'm looking into getting solids for my ss, had prothane mounts in my z28 and loved them.
Old 10-03-2007, 08:56 PM
Grifter's Avatar
Do a quick search and you'll see that most people who have them love them. A lot of the people who knock them have never even ran them.
Old 10-03-2007, 09:12 PM
I just decided I'm gonna do them anyway, if i don't like it or gives me problems I'll change em out.
Old 10-03-2007, 09:55 PM
True. I guess I didn't think that all the way through haha. You would have to get the sway bar as well. The key is that you'll be doing it on a lift and that will be a lot easier than jackstands. So either way should work out well. And you're right about the PS lines. I've read about a couple people lifting the motor too much and cracking a line.
Old 10-03-2007, 09:58 PM
Likestogofast's Avatar
Just go solids and don't look back. My wife couldn't even notice a difference and the power delivery is much better and instantaneous. No need drop the k member. The stock mounts are a pain to get out but nothing you can't handle after moving the alternator and the ac compressor out of the way. Once the stock mounts are out the solids do go in pretty easy.
Old 10-03-2007, 10:12 PM
TheSilverOne's Avatar
i swapped to spohn solids while doing my headers. it was easy with the exhaust manifolds out of the way. i didn't move the alternator or ac compressor out of the way. i had the car up on jackstands and placed a 8 x 8 piece of wood between the oil pan and jack to lift up the motor a little bit when removing the stock mounts.
Old 10-04-2007, 06:46 AM
Grifter's Avatar
Yeah, you are right. I would have to unbolt it from the frame.
Thanks for the input guys.
Old 10-06-2007, 12:05 PM
Grifter's Avatar
I just got a look at the mounts on the lift. They actually don't look that bad. I don't think dropping the k-member will help too much, maybe just lowering it alittle.
Thanks for the input.
Old 10-14-2007, 10:56 AM
Grifter's Avatar
I got the Spohn's, now I'm just waiting to install them.
Old 07-16-2010, 01:08 PM
BFarrier's Avatar
i install my Spohn's today there coming to be deiliver in about an hour and then off to work at the shop!!
Old 07-16-2010, 02:03 PM
Old Geezer's Avatar
Talking Mine either!
"My wife couldn't even notice a difference"..
But, my g/f likes the "sensation"!!
Old 07-16-2010, 05:33 PM
98RedBird's Avatar
Solids are CAKE to install. Much easier than poly's. Just throw a block of wood under the oil pan, lift it up, pull the old mounts out, and throw the new ones in. Not hard at all. I've had both and I like them both. They both have their pluses. FWIW, I didn't really honestly notice much of a difference in vibrations jumping between stockers, to poly's, to solids...
The one's that tell you that they are going to rattle your teeth out are ignorant and haven't tried them. They just want to SOUND like they know what the hell they're talking about...
Old 07-16-2010, 05:36 PM
ss.slp.ls1's Avatar
When I install solid motor mounts, I support the engine and unbolt the k-member bolts and steering knuckle while leaving the shocks and a-arms bolted. The k-member will hang a good 4-5" lower minimum. I slip the mounts in place, loosely thread them into the block and then raise the k-member back up. Then I loosely thread in all of the bottom bolts into the k-member and then I snug everything up. I am usually only doing mounts when I am doing headers at the same time, so that makes it easier too.
Quick Reply: Solid Motor Mount Install Idea.
