Causes Of Rough Idle
Old 10-03-2007, 01:56 PM
01LS1WS6's Avatar
Default Causes Of Rough Idle
What Are The Causes Of Rough Idle, Besides Vacuum Leaks, Dirty Throttle Bodies, Plugs, Wires, And Etc. Also What Is The Best Way To Find A Vacuum Leak
Old 10-03-2007, 03:15 PM
Ryanmgaspard's Avatar
Well my MAF had a broken wire inside it and caused a rough idle and caused the car to randomly die and shake. Also, I seafoamed through the brake booster and it fouled my plugs out. All were black except #8. I know you don't wanna hear that but FYI.
Old 10-03-2007, 03:17 PM
GregWS6&z28's Avatar
you can spray carb cleaner around the engine and if it dies down some you have found the spor of your leak.
