83MM Airesearch turbo
I looked on here and did find a little info on it.
Compressor Wheel Inducer ( mm ) - 83mm
Compressor Wheel Exducer ( mm ) - 101mm
Turbine Wheel Inducer ( mm ) - 101mm
Turbine Wheel Exducer ( mm ) - 91mm
Turbine Inlet Flange - T-6
Turbine Housing Outlet - 5 Inch V-Band
My A/R is 1.08
I know what it can do on a built 6.0L But I have a feeling it will work even better on a 408. Anyone have a compressor map on this turbo by chance?
My A/R is 1.08
LS1TECH Sponsor
We have the comp map for it I believe, its still available. Its an older TV84 unit and will flow around 93lbs/min. Not a good flowing wheel and spools slow. Also its an older flat back wheel which is hard to find any upgrades for as well.
