LS2 Flywheels Confused?
So whats the deal on this? I look at summit and jegs for LS2 flywheels and all I find are LS1 stuff. I have an 06 LS2 and am in need of a flywheel. Are the flywheels interchangable between LS1, LS6, LS2, LS7?
Any input would be great, also if you have links to vendors that sell them even better. I just don't want to go to GM direct, they are way high.
Thanks
Ben
Thanks
Ben
Location: Your girl's back door giving her the long stroke while you're at work
The LS1/LS6 are totally different. They will not work with the LS2 clutch PP and disc. Just FYI the LS2/LS7 flywheel are the same. Check with Fidinza(sp??) I think they make a lightweight flywheel for the LS2 assembly.
