Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
can I use 1.6 rocker arms?
Old 10-08-2007, 09:51 AM
proxemics's Avatar
Default can I use 1.6 rocker arms?
If the heads specs says 520 is the max lift and my cam is 515 can I use 1.6 rockers?
If I did my actual lift will be about 550" can I do this without upgrading the springs?
the heads are dart pro 1
also my combo will be like this
388 10.7:1 compression
dart pro 1 heads
lunati flat tappet cam 515 lift 446 duration @0.05 .cam range(2500-6000)
performer RPM air gap intake
holley 750 DP
intake 2" spacer
150hp nos shot
th350 trans
ford 8.8 rear end with 4.10 gear
how much stall I need?
Old 10-08-2007, 10:06 AM
jmm98LS1's Avatar
If your springs are only good to .520", then no you can't run 1.6 rockers without upgrading valvesprings. You'll need springs good to ~.575" lift.
Old 10-09-2007, 09:59 AM
proxemics's Avatar
are these good?
http://store.summitracing.com/partde...5&autoview=sku
Old 10-09-2007, 11:32 AM
CNC BLOCKS N/E's Avatar
dart pro 1 heads
holley 750 DP
intake 2" spacer
150hp nos shot
th350 trans
446 duration @.050 how can that be??????????
Old 10-09-2007, 11:44 AM
goes12s's Avatar
your spring will not handle that much lift, so it will better to replace them
Old 10-09-2007, 11:50 AM
proxemics's Avatar
246 >>>>>>
Old 10-09-2007, 12:21 PM
1997bird's Avatar
Is this a hyd. flat tappet or a solid flat tappet cam?
The other thing that you need to measure is your valve spring installed height before looking for a cheap spring.
Old 10-09-2007, 05:07 PM
proxemics's Avatar
It is a hyd. flat tappet
Old 10-09-2007, 05:50 PM
1997bird's Avatar
What is your valve spring installed height?
Old 10-10-2007, 09:02 AM
proxemics's Avatar
I don't know about this
Old 10-10-2007, 11:48 AM
1997bird's Avatar
More than likely they have a 1.85" installed height on them. If you have a caliper you could check that out in just a few seconds. Take your caliper and put the flat of your slide on the edge of the valve spring and then run the middle of the slide down until it rests against the valve spring locator. That will give you a quick referance to the installed height needed for your heads.
Old 10-20-2007, 12:49 PM
proxemics's Avatar
I checked them today they have 1.7" installation hight given this info what springs should I use?
Old 10-20-2007, 10:20 PM
1997bird's Avatar
I would go with this set of valve springs, http://cgi.ebay.com/ebaymotors/SBC-C...QQcmdZViewItem . You will need to have some machine work on the valve spring pockets in order to use them. I do not know of any spring with a 1.7" installed height that would be able to handle the lift that you are going to have with the 1.6 rockers.
Quick Reply: can I use 1.6 rocker arms?
