tci flywheel choice for th-350 swap?
Old 10-08-2007, 07:14 PM
van383's Avatar
Default tci flywheel choice for th-350 swap?
doing a th-350 conversion which tci flywheel would i use #399273 168tooth all engine dual pattern or the #399753 ls1 small bolt pattern version? thanks
Old 10-10-2007, 10:09 AM
Kevin Winstead's Avatar
If you're mating the TH350 trans to your LS engine, you'll need the 399753 flexplate.
Quick Reply: tci flywheel choice for th-350 swap?
