catch can install?
catch can install?
hey can anyone direct me too a sight or how to install a catch can on a 98 z28? it has 3 niples on the catch can, 2 side by side on top & 1 at the bottom. the clear hose with the kit is 18" long, is that enough for the 3 nipples to hook up were ever they go? thanx john
14 Second Truck Club
The very bottom is usually the drain, the hose on top goes to the valve cover (or valley cover if you have the LS6 style), and the one under it goes to the intake.
http://kb.ls1gto.com/KB/article.aspx?id=10001
Mine looks like that except I still use the PCV valve. If you dont have the LS6 valley cover then you would hook it up to your PCV line that goes to the valve cover.
