Pics Inside is my Driveshaft too Long???
I got my 12 bolt installed with Spohn Relocation Brackets. BMR LCA's and torque arm. I have the pinion angle set. The driveshaft is a Dennys Nitrous Ready shaft. The yoke is right up against the t56 seal, what do you think? Im ready to order a set of Adjustable LCA's to pull the rear away.
possible resolution
Well i called SJM Manufacturing, Steve was great. He is making me a custom set of LCA's. He is going to make them so that when the adjusters are at there shortest point they will be the factory length. That way i will have 1.5 inches of extension to move the rear back. I hope that works. I also bought the adjustable panhard bar.
