Engine noise
Engine noise
Hey everyone. I have a 01 SS with about 56,000 miles. The problem i have is a knocking sound coming from the motor. It sound like its coming from the passenger side. At an idle the noise is still there but it only gets really bad at about 2k rpm then seams to go away(or at least a bit quieter) If i could get some help with this that would be good. Also some times when i go to start my car ill get like a back fire and then the car will stall but if i get it a little gas and it will start fine I had it taken in for both issues and it was not tripping any sensors. Im new to the ls1 and im not sure what it might be
yeah, my bet is a rod knock. i wouldnt drive it much untill i find out for sure what it is. if it is a rod knock you dont wanna drive it to where it knocks a hole in the block. that, and the more you drive it the more damage you will end up doing, in otherwords, right now the problem maybe in your bottom end, but it could spread to your heads, and then its gonna get even more expensive
