TWINS: hot side balance
Twin turbo guys
Are you running a "balance" tube or pipe on your hot sides. to equal out the pressure from one hot side to the other ? I am not asking about the turbine discharge side (exhaust not under pressure), but the turbine inlet were pressure can get high. I have twin t3/t04b setup and the only thing linking the two turbos together is the cold side pipes that meet at the intake.
I would rather not have to fab more pipeing but if there is performance gains..............
