Whats it worth?
Whats it worth?
I have a car im getting ready to sell....just wondering what you guys think its worth? What should I ask for it?
1994 Chevy Camaro z28, Burgundy, T-top, M6, 140k on body 900 miles on motor
No longer has heat or A/C.
-396 stroker lt1, bored .30 over, aligned bored, squared and decked, clearanced for stroker kit
-Eagle forged crank 3.875
-Forged eagle h beam rods
-Forged SRP flat top pistons
-AFR 210cc heads, slight bowl work, 208 intake 160 exhaust
-11:4:1 w/ 64cc heads
-ARP main studs
-Clevite h series coated bearings
-Canton 7qt oil pan w/ windage tray
-Scorpion rocker arms 1.6
-Comp Chromoly push rods
-Comp pro magnum lifters
-Custom grind comp cam 242/248 585/580 113+4 lsa
-AFR valve springs (600 lift)
-MLS head gaskets
-Port matched lt1 intake manifold
-Eldebrock twin 58mm throttle body
-K&N cold air intake
-42lb injectors svo
-Chrome Chevrolet valve covers
-Bilstein shocks
-Eibach Prokit
-Subframes connectors
-Strut tower brace
-Pan hard bar
-ls1 aluminum drive shaft
-Jet Hot LT headers
-2 1/2" true duals H pipe dumped before axle (dynomax bullet mufflers)
-MSD 6al box
-MSD opti spark disributor
-MSDwires 8mm
-Spark plug wire protectors
-Chrome alternator relocation bracket
-Rear mount optima battery
-3.73 gm gears
-Spec stage 3 clutch
-Neutral Balanced LT1 flywheel
-Hurst short throw shifter
-Corvette ZR1 rims, 17x9 1/2 fronts and 17x11 rears, gunmetal w/ chrome lip
-Sumitomo 275/40/17 &315/35/17
-Aftermarket hood
-Race spolier
-Rear view camera mounted in trunk key hole
-2 12" Audiobahn subs and Sony amp
-DVD Player
-Racing seats JDM
-Pioneer head unit
-Rear veiw mirror mounted tv 7"
TONS and TONS more mods!!!!!!
Thanks!!!!
-ARP main studs
-MLS head gaskets
-42lb injectors svo
-Bilstein shocks
-Eibach Prokit
-Strut tower brace
-Pan hard bar
-Jet Hot LT headers
-MSD 6al box
-MSDwires 8mm
-3.73 gm gears
-Aftermarket hood
-Race spolier
-DVD Player
-Racing seats JDM
-Pioneer head unit
Thanks!!!!
