Anyone order a Mcleod MC rebuilt kit lately?
I had one rush ordered as I found mine was leaking. I took it apart finding the plunger itself and the spring behind it totally different than the original.
The new plunger was shorter in length and seemed loose in the cylinder compared to the original. The spring that came with the kit was longer which would make up for length difference of the plunger, but the diameter of the plunger doesn't seem right.
They send you a WildWood brake rebuild kit which contains other items. Another funny thing is the little rubber seal that goes between the plunger and the spring was not in the new kit. So basically the kit is totally different and doesn't contain similar components along with no instructions.
Any one else had this problem?
