Where is my clutch fluid going?
Old 10-23-2007, 08:44 AM
1fastWS6's Avatar
Default Where is my clutch fluid going?
Car is an '01 with bone stock hydraulics....never needed to add fluid since new. It's had a Spec 3 in it for about 37k miles. Now with ~50k miles on the car, the clutch pedal starts acting funny. Check fluid level, and the reservoir is empty. Fill it up, pedal is fine again. 2 wks later, same deal, fill up again. Third time now I've had to fill it in a month. Its not dripping on the ground, no signs of it under the car at all. I assume it has to be the slave leaking.....but where the F is it going?
Thanks,
Craig
Old 10-23-2007, 11:48 PM
wrencher
wrencher's Avatar
Check the master cylinder where the rod connects to the pedal inside the car under dash. The master can fail & seep fluid here & cause problems. If it is wet in there & leaking a new master you will need.
Old 10-24-2007, 09:58 AM
Hugger Z's Avatar
When my slave started wearing out I would get a little fluid dripping out of the bellhousing. And some on the old clutch too once I took it all apart.
