LS7 Clutch/LS7 Flywheel
I am about to order a Ls7 clutch setup and i was aondering if the Ls7 flywheel and the Ls2 flywheel from the vette are the same. There have been many threads saying both will fit on our Ls1s but no one has given a straight answer. Anyone know? Also will this clutch hold up at the 450rwhp range?
I found the ls7 clutch/ls7 flywheel for $259 and wanted to buy it but wasnt sure. I am going to be doing the PRC 2.5 5.3l setup with ms3 cam. Will this clutch holdup with the power added by the heads/cam. The clutch will see no track abuse and i usualy just walk the clutch out instead of dropping it.
LS1TECH & Trucks Sponsor
Yes, the LS2 and LS7 use the same flywheel!
And if you found the LS7 kit for $259, PM me where at....I'll start buying all our stock from them!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
