LT1 WS6 HID housing options?
so who makes what when it comes to the 93-97 trans am headlights? I want HIDs and i havnt looked into itm uch cause i always had an LS1. I know someone makes the lenses so you can just plug in play right?
no, for the most part, you have to buy a conversion kit according to the bulb number. If you a 9006 for the low beams, you would buy a conversion kit for a 9006 bulb set up... i have never really seen a vehicle specific set up...and they are never completely plug and play. always require a ballast set up that is wired through a relay, using the factory wire as a trigger... the lenses dont make a diffrence in terms of the actual HID light, they only focus the light diffrently... just because a car has a "projector" lense, does not mean it has HID's or visa versa...
