Sponsored by: DashLynx
Anyone have pictures of an AEM wideband in a T/A center vent?
Old 10-26-2007, 12:09 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Default Anyone have pictures of an AEM wideband in a T/A center vent?
I searched with no luck. I'm thinking of getting an AEM wideband with the gauge and am considering putting it in the vents in the center of the t/a dash. The only issue is that the gauge is 2 1/16 in diameter and I'm not sure that's going to fit.
Thanks.
Old 10-28-2007, 08:09 AM
UNDER PRESSURE MOD
No one????
Old 10-28-2007, 09:23 AM
LS1Tech Sponsor
Superman09's Avatar
2 1/16" will be too small for the center vent so you will probably have to make some type of bezel for it to sit in there.
https://ls1tech.com/forums/showthrea...ts#post4090448
Page 3, Bad30th
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 10-28-2007, 12:06 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
My AEM wideband is in my pillar pod, but I have an aeroforce interceptor in my center vent location:
I used the cap of a krylon spray paint bottle. Trimmed it down and cut it at a slight angle so it faces the drivers seat a little more. Then cut out the 2 1/16 hole for the gauge. Then added some electrical tape to the outside of the cap to get a tight press fit into the vent hole.
Old 10-28-2007, 02:40 PM
UNDER PRESSURE MOD
Thanks for the pictures guys.
Quick Reply: Anyone have pictures of an AEM wideband in a T/A center vent?
