Not getting power to Jensen headunit
Here's the deal. I have this Jensen single disc cd unit in my car. It worked completely fine up until Friday when I took it out. I am now trying to put it back in but I can't get power to it anymore. It has an adapter that plugs & plays to the factory wires. I made sure all the wires on the adapter were good to go. I changed the fuses in the adapters and in the "filter box", I looked at the fuses in the dash and popped some new ones in. For some reason I still can't get power to the headunit. Why this problem?
get one or borrow one to meter to see if you are getting power, if so the unit is bad, if not check fuses and connections. if no power at jensen side of plug, check car side of plug.
