RPM limiter, 2 step, 3 step, Harlan, MSD, etc.?
I'm going to need some kind of rpm limiter for the new setup so that I don't come out of the hole as hard because with the old setup, I was having a hard time keeping the front down. Now with a much more aggressive setup, I'm sure it's going to be an even bigger problem.
Last I read, Harlan wasn't making 2 steps anymore. The only thing I've come across is MSD. Is there anything wrong with the MSD? Is Harlan making them again?
How do I determine if I need a 2 or 3 step? I'm not even sure what the difference is.
Because my converter flashes to 5800 rpms and I'm not sure if I want to come out of the hole that hard off the transbrake.
Can you be more specific for the burnout? Why would you need the rpms limited while doing a burnout?
Lingenfelter, PnP? Plug and play?
I do have a set of travel limiters and I plan to tighten them up, but I still would like to get a limiter.
7 Second Club
strap the front down and tighten the shocks... if that still doesnt help get BS3 and pull a few degrees of timing on the starting line and curve them back in by the 60'... ofcourse the curve/time will depend on how much you pull at the line...
Swapping over to the BS3 is a bit much. $2400 is an expensive solution for trying to control my wheelies.
Which one of these is the one I need? The 1st or 2nd one?
http://www.lingenfelter.com/store/c163.html
7 Second Club
you can control your wheelies by other means... like letting air out of tires to get more wheel speed or strapping the front down... but it sounds like your a race car and some time or another the BS3 will save you lots of time and trouble...
