grinding in 3rd
Old 10-30-2007, 04:30 PM
dutinsss's Avatar
Default grinding in 3rd
i have an '02 SS M6. i was riding home today, just playing around, shifting down to 3rd going about 70ish at a cruise, letting off when i hit 4th and the next time i tried shifting into 3rd, it grinded rele bad. i had the clutch fully engaged. i had to force it into 3rd. but i noticed it only does this if i drive it hard. if i waited about a minute or so, it shifted fine. i'm pretty sure its only 3rd gear that does this. can anybody tell me what the problem is? thanks
Old 10-30-2007, 08:48 PM
thesource's Avatar
Could be a syncro ring on its way out or could have been a slave cylinder issue .
Old 10-30-2007, 09:18 PM
dutinsss's Avatar
i was thinking it was the synchros after reading a few other threads. if that was the case, would it only grind after being drivin hard? or would it grind no matter how i was driving it? and would doing the drill mod help at all?
Old 10-30-2007, 09:57 PM
thesource's Avatar
try bleeding the clutch out and see if that fixed anything .
Old 10-30-2007, 10:08 PM
dutinsss's Avatar
will do. it'd be great if this fixes it because i'm rele not looking forward to tearing into the tranny
Quick Reply: grinding in 3rd
