th 350
Old 10-30-2007, 08:11 PM
ls1pwrdss's Avatar
Default th 350
ok i want to put a th 350 in my car
i will be using a umi tunnel mounted torque arm
pst drive shaft
what will i need as far as a crossmember and how long of a tail shaft do i need
Old 10-30-2007, 09:28 PM
LS1Tech Sponsor
performabuilt's Avatar
With the long tail 9 inch 350 the stock length drive shaft will be fine . With the short tail 6 inch the shaft will need to be three inches longer. Not sure on cross memebr as I have never personally done this swap as I never thought it a great idea except for dragsters. But I hope the little info I have give is helpfull.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 10-30-2007, 11:47 PM
ls1pwrdss's Avatar
its been done i know tick performance has one in there car
Old 10-31-2007, 12:13 AM
josh2002-ws6's Avatar
As for the crossmember I know BMR makes one but have not seen anything from UMI or Spohn. The BMR should run you about 180 dollars. Here is the link to the page for BMR: http://www.gnetworks.com/v4/go.gnf?s...&currentPage=3
Old 10-31-2007, 01:50 PM
billybadd's Avatar
I think a stock m6 crossmember works.
Old 11-01-2007, 12:41 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Yes sir. Thank you for the PMs!
Old 11-01-2007, 06:26 PM
ls1pwrdss's Avatar
thanks for all your help on this joey. so you think i should have no problems taking the 4ljunk out and go th350 with no problems
