what all is needed for pulley change?
i want to do crank and alternator pulley. obviously i need the crank and alternator pulley but i see balancer bolts and other things being sold either seperately or as a package on different sponsors' sites. what is everything i need to do this right the first time?
Re: what all is needed for pulley change?
You'll need a new crank bolt, 76" serpentine and 37.8" a/c belts. You really don't need the alternator pulley unless you are running a big stereo that is sucking up your amperage.
thanks for the info. but on the subject of the alt pulley: i was thinking i would want an underdrive alternator pulley because im not,and dont plan on, running a big stereo that would suck up my amperage
If you're not going to be running anything that draws a significant amount of ampereage, all you really need is the crank pulley. I have been running mine this way for about a year with no ill effects.
