97 WS6 panic oddity
97 WS6 panic oddity
No key FOB, going to get one here in the near future, but occasionally when you open or close either of the doors the panic will go off till you put the key in and even just move it to start. Not a big issue, not like the car won't start, just sorta annoying. Any idea?
Ungrounded Moderator
That is normal function when the car's content theft deterrent system (alarm) is set. I'm sure you'll find that the common factor is that you locked the car using the inside switches on those times that the alarm sounds (locking with the key doesn't activate the alarm system). Unlocking doors with the key doesn't deactivate the system which is why the alarm sounds until you turn the key in the ignition.
