Parking Brake 9" modification
I'm getting ready to put my 9" in the car. Does anyone have a pic of how they mounted their parking brake cable?
I hear that you have to cut the "P" cable in half, but I want to make sure with a pic.
I also am looking to mount that brake line bracket that was mounted on the original 10-bolt. If anyone has any ideas other than zip tying post them up.
Any pics would be apreciated.
Thanks guys.
Thanks guys.
I just got done installing my 9". The brake line bracket got welded to the top tube for the TA mount and I also welded the two park cable brkts that used to bolt onto the cover to the 9" case. The far one on the pass side axle tube was mounted as factory by drilling an approx 1/4" hole in the back side of the Rt LCA mount. The brake lines got extra wide zip ties till I can make some weld on tabs for factory type mounting.
