I Need Help With A Leak
Ok heres my problem i have water coming from under the dash even when its not raining at first i though it was the a/c so i quite useing it but the problem continued the water is comeing from under he passenger side of the dash. i have a 2002 Z28 can someone help.
Try posting in a technical section. You'll probably have better responses there. This is the new member intro/greeting section. Good luck with your problem.
