Easiest way to install axle bearings
Old 11-09-2007, 03:42 PM
1BADASS35th's Avatar
Default Easiest way to install axle bearings
What is the easies way to install new axle bearings?
Old 11-09-2007, 04:38 PM
ls1pwrdss's Avatar
its not an easy task if you dont have the proper tools.
you need a slide hamer and a bearing and bushing intaller kit
you can get both these items at either pep boys or sears or jeg and summit
its not hard you have to remove the caliper and bracket, rotor the remve the rear cover and take the 8 mm bolt out of the pin and slide the pin out remove the c clip and remove your wheel speed sensor then slide your axle out then take the slide hammer ull bearing and seal out at the same time. then install the new bearing with the installer proper size the install the seal
then reverse the process and fill with fluid and limited slip addative if you have a auburn unit. hope this helps
