Which rearend fluid?
Old 11-11-2007, 08:51 AM
Carter01's Avatar
Default Which rearend fluid?
Ok, I've been searching for about an hour now and I can't get a clear cut answer about which fluid to use. I have a 99 Camaro, 7.5 rear with Eaton Posi unit with Kevlar Clutches and 410s.
1. Which fluid is recommended, Syn or Non-Syn?
2. Do I use the addative or not since I do not have the Torsen I have the Eaton w/Kevlar clutches?
Thanks
Old 11-11-2007, 09:10 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Non-synthetic, and you need the additive.
Old 11-11-2007, 09:22 AM
Carter01's Avatar
Thanks for the help!
Old 11-11-2007, 02:35 PM
omcar's Avatar
I agree.. just did mine. same set-up except 3.73s.
