P1SC + 385 ci LT4 Question
I am trying to figure out my best options for setting up the "most efficient" engine combination for mainly street use (not a max effort or track car).
Engine:
385 ci LT4 built by SDPC
Callies Magnum Crank
Manley 5.7 rods
JE flat top pistons
10.5 to 1 CR
Titanium retainers, SD1007 valve springs, manley steel valves
Lingenfelter Ported heads and intake
4 bolt main LT4 block
Gm LT4 Hot cam
485 FWHP at 6300 rpm
467 FWTQ at 4600
I want to run this engine with a Twin Intercoooled P1SC Procharger system at about 7-8 psi (to keep pump gas). I already have this kit otherwise I would have gone F1 or Turbo.
I already plan to buy...
60 lb/hr injectors
Walbro fuel pump
Pacesetter LT headers and Y pipe
Custom dyno tune
MSD Pro Billet Opti
Will this combination work for street use, and make about 600 RWHP?
Would a cam change, front mount intercooler, D1SC upgrade, or Piston change really improve this setup to justify the cost? I don't want or need over 600 RWHP, but I want to get near that number.
Any recommendations would be great.
Thanks
Engine:
Manley 5.7 rods
JE flat top pistons
10.5 to 1 CR
Gm LT4 Hot cam
467 FWTQ at 4600
60 lb/hr injectors
Walbro fuel pump
Custom dyno tune
MSD Pro Billet Opti
Thanks
A P1SC on a built 355 would do 600RWHP IMO.
That 385 is a pretty efficent motor, and a P1SC would not have to work overally hard to achieve your goals, so pump gas would not be a problem (Hell 15lbs can be done on pump gas) Just get a REALLY good tune and make a 4inch setup off the blower, the stock ATI setup is very restrictive on the LTX cars.
I'm not sure if that FMIC from Exotic performance will work with a 93-97 Trans Am nose.
Maybe Bob will will chime in on this thread and let us know... I would love to find out myself!
Engine:
Manley 5.7 rods
JE flat top pistons
10.5 to 1 CR
Gm LT4 Hot cam
467 FWTQ at 4600
60 lb/hr injectors
Walbro fuel pump
Custom dyno tune
MSD Pro Billet Opti
Thanks
Engine:
Manley 5.7 rods
JE flat top pistons
10.5 to 1 CR
Gm LT4 Hot cam
467 FWTQ at 4600
60 lb/hr injectors
Walbro fuel pump
Custom dyno tune
MSD Pro Billet Opti
Thanks
First of all I love your car I am pretty sure I have seen it on cardomain. I think you should just get a D-1 kit and don't waste anytime with the P-1sc, Also you have a built motor that will def support a D-1 with 15 psi that will get you to 750rwhp. Also I have researched alot and a self contained on a LTX motor will get too hot because our unit is close to the header and they leak because the seal will get too hot and there goes all the oil and the blower will ****. If I was you I would def get a just a D-1 kit. Talk to Bob he is extremely helpful. But I understand because you already have the kit if 600 is your goal then go for it.
reading is good
Don´t get a MSD opti get a LTCC or Delteq ignition
Get a Custom Cam from Lingendelter or to match the Port work or Port Pros,Cam Motion are good
Keep the P1sc
600rwhp is not a goal,that´s esay
Keep the P1sc
Your Green Dragon looks badass. That should be a great combo - very similar to what I am running, except mine is a 383 SBC with Vortec-style heads instead of LT4.
Plenty of low end with the cubes, kickass mid-range and screamin top end...
Jim
Jim
Thanks guys this is all great information. This engine combo is actually for my 93 Orange and Black TA, the Lime Green TA is still waiting for an engine.
I'm only shooting for 600 RWHP so I don't need to upgrade the Transmission AGAIN (I just bought the Performabuilt Level II) and I can use the stock fuel system with an upgraded pump and adjustable fuel pressure regulator.
With the EPP Front Mount, since there kit is designed for the LS1, do you just order the intercooler for $299 or will all the piping work for the LT1?
-Is a Cam swap necessary to get 600 RWHP?
-What would be the better upgrade the MSD Opti or the Delteq?
I have had the Delteq on my car since about a week after they came out, same wires and everything. I plan on using it still here in a few months when the blower setup goes in.
I can't back what I'm going to recommend with experience...
Even though it's a small blower, I think it'll get you there because the LT4's flow really well. But, I would get the FMIC if you don't mind doing a FMIC. You're looking for a reliable street car.. Keep the IATs lower with a FMIC, tune to 600rwhp, and you can avoid some detonation.
Personally, I know where you're coming from about pump gas... I don't want to be adding meth, race fuel, anything like that... But LS1tech has convinced me otherwise.... Either add something to your pump, or just don't set your goals to high.. My goals will be higher than yours, but you're using pump. You're putting trust in a gas station actually giving you the 93 you're paying for... (Although I don't think the FMIC is required) If you're getting something lower than premium 91-94 octane, a FMIC will give you an extra layer of security
I bought epp's front mount and did my own piping, but I hear the piping for ls1 cars is just slightly different for us lt1 folks.
As far as the self contained units heat soaking issue and ruining seals, I have yet to run into any problems on that issue.
Good luck with the build!
I'm sure it gets plenty of air with the nose off, but how's it's efficiency with the nose on... it dosent get the license plate cut-out like the LS1 front end.
I am wondering the same thing! I do not want to cut any holes in the nose of my car! Can holes be cut in the bottom of the nose and deflect enough air to the intercooler?
Our front mount intercooler kit will indeed work with an LT1, only one tube needs to be reworked. We did the LT1 front mount intercooler install on Call911's Camaro, and it came out really well.
Call911 drives his car back and forth from New Jersey to Indiana quite often, as he has relatives in Indiana.
As far as heat with the self contained ProCharger on an LT1 F body, we have never had a heat problem with them. My brother's '95 Formula has had an ATI ProCharger P-1SC for five years with no problems. http://www.exoticperformanceplus.com...tCar.php?car=7 Bob
I've got Bob's FMIC kit as well and it needs modifying. How much is up to you but it can be done w/ modifying the one tube. I modified 2 tubes as I wanted it to tuck up better underneathe the car. You can view my pics here to get an idea. It is a great kit for the money.
http://fbodyeurope.org/Gallery/main....y-Ghost-Album/
We (those of us with LT1 Trans Am noses) would like to know if your FMIC has ever been applied to our style of front end?
If so, how is the efficiency of your FMIC affected by the LT1 T/A nose (if at all)?
Can anything be done to increase it's efficiency with the LT1 T/A nose... aside from cutting a gapping hole in the front?
Again... This is for a LT1 Trans Am nose.
I mean absolutly zero disrespect with my line of questioning... just want to know if your product is an option for our cars. I really want it to be an option, as I've narrowed down my future forced induction plans to a F1A + FMIC from you, or just sending the whole damn car to SPEED INC for a custom turbo setup.
Believe me, my wallet wants your option to be #1... and I'm inclined to agree with it. But I want results and my money will go where I can get them.
GrnDragon - Been following your car for a while... your T/A is mint!
