Alternator light will not turn off
Old 11-15-2007, 08:03 PM
under pressure's Avatar
Default Alternator light will not turn off
I am running a stock Vette alternator in a stand alone Megasuirt setup. I followed the instructions in the Speartech postings about wiring the B and C pins on the alternator connector. The dash bulb I am using comes on with the key but does not go out when the car starts. The alternator is putting out about 14.5 volts while running. Do I need to add more resistance to the dash light wire? I am using an accessory bulb from an Autometer gauge as my dash lamp. Any suggestions? Thanks for looking.
