?????lug sizes??????
already asked in the wheels and tires section and couldnt get an answer.
just ordered pro stars and the problem is, i have a moser 12 bolt with 1/2" studs and they are longer than the stock ones, so i don't know what lug nuts to buy. nore do i know which ones to buy for the front, they are stock. any help with the right 1/2" spacing and the stock ones in the front would be greatly appreciated.
matt
matt
Did you get the drag racing size studs on the rear? If you did you might have to run a standard open style lug nut that is a acorn style. if they are the standard size stud. any acorn style 1/2 inch will work. I forget the oem size but I bought mine at checkers and they have a sizeing chart there to help you out. It's a mm size and I forgot what it was.
I have 1/2 inch studs on my 9" and the standard size acorn closed lugnuts worked fine.
