GTO AC compressor - swap to SS or TA AC compressor
Old 11-20-2007, 06:09 PM
240SX GTO's Avatar
Default GTO AC compressor - swap to SS or TA AC compressor
I'm currently in the process of 2004 GTO swap in a Nissan 240SX and having trouble with the 2004 GTO AC compressor inlet/outlet fittings and lines that are located on the SIDE of the compressor housing. The problem is, I have no room as it is too close to the car body rail. So with this in mind, the 2002 Camero SS compressor inlet/out let are in the rear of the compressor and would be perfect for this application. Does anyone know if the mounting brackets of the 2004 GTO AC compressor housing line up with the brackets for the following cars/yrs as listed below?
Your help would be greatly appreciated - too bad this 2004 GTO motor set has 5,700K as so does the
AC!
Year Make Model Engine
2002 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
2002 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
2002 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
2002 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
2001 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
2001 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
2001 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
2001 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
2000 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
2000 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
1999 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
1999 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
1998 PONTIAC FIREBIRD FIREHAWK V8 5.7L 350cid GAS FI N Engine VIN = G
1998 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
1998 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
