need info
Old 11-21-2007, 05:22 PM
camaro468's Avatar
Default need info
i am trying to find out what gears my 98z has in it i think the code is gu6 its a 6sp i am trying to program it
Old 11-21-2007, 06:36 PM
keliente's Avatar
If the code is GU6 it has 3.42s.
Old 11-21-2007, 06:38 PM
tording99Z28's Avatar
That and I am pretty sure all 6 spd cars have the 3.42 gears. Only the A4's have the 3.23 and the 2.73's I think. Someone correct me if I am wrong.
Old 11-21-2007, 07:01 PM
camaro468's Avatar
can i go with a 410 and still be fine on the high way
Old 11-21-2007, 07:50 PM
I am not sure exactly what you mean by "fine on the highway" but I am guessing you are talking not turning too many revolutions while crusing at 70 MPH. With the 6 spd and 4.10 gears you should be fine on the highway. I can't imagine turning more than 2500 rpm's at 70 mph. This will affect your MPG a little but but shouldn't be all that much really. I say go for the 4.10's.
Edit: Its not even that high. Looks like you would be looking at about 2k rpm's at 70 mph. This chart shows the speed and mph for different gears.
https://ls1tech.com/forums/attachmen...6&d=1126021825
Old 11-21-2007, 09:20 PM
camaro468's Avatar
thanks a lot for the info
