T/A Fog Lights
T/A Fog Lights
Whats everyone runnin' and how did you install them? I heard its a biatch with the way the bottom of the car is setup in. Any way you can use the same bracket??
Where can you buy the fog lights with the Blue ring on the outside that lights up? I think there like Halo angel eyes or something like that. Thinkin about gettin a set for my NBM T/A
i dont have the halos on ever but the fog lights are bright and look good.
i think the seller is like bling lights or something.
Copy & Paste Moderator
Check out the "Lighting FAQ".
Its in the "Hall of Fame" sticky.
Its also in my sig.
Here is a link for convenience:
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
Its also in my sig.
Although the Cyber White Fog lights that I have (that's my site listed in the Lighting FAQ) do have a halo with different color options, its not all that bright and there is no way to permanently set the LED color using the control panel that comes with it. Every time you turn them on, they are a different color. I left them disconnected.
I had just generic wal-mart ones in the blue car, my others were cracked and I was cheap at the time. I adjusted drilled holes in the stock mounts and the ones that came with the foglights to make them work. Later I found out that you can bend the stock housings to bolt right up to the fog lights. Here is the best pic I have, sorry you can't see them perfectly.
I had silverstars and they both blew out on me at the same exact time about a month after I installed them. They were a huge bitch to put in. I hate silverstar bulbs. I'm back to factory now.
